One can apparently not find a Charging Dock DK 31 (which is specified for the Z1) here in Bangkok. The Sony people told me that the DK 30 (which is specified for the Xperia Z Ultra) will work perfectly with the Z1, but I wanted to ask you folks. Both docks seem to have quite similar specs.
You can use DK 30 if you change to the thicker included spacer. It's not a perfect fit but it will work. For a better fit I suggest that you use DK 31.
Thank you.
