Scene Options and HDR
willsation
Hello.
I seem to be missing a couple of options in the Camera menu. I cannot find the HDR function at all and I can only access the Scene mode in the Video function.
I would appreciate your help.
Many thanks
Peter
azzido
Enthusiast
I guess that HDR is available only in manual mode and only in 8MPx resolution 😕
I don't know why.
When it comes to scene selection, it is available in manual mode, again in 8MPx only...
However, HDR feature need a lot of improvement as at the moment I can't see any difference between HDR on and off.
I alsowould like to see an option for more resolutions 16:9 - higher that 8MPx, 16MPx or even 20MPx 16:9 would be nice.
Thank you,
7 REPLIES 7
Uliwooly
When you open the camera > settings > you can't see the HDR icon? (scroll down)
azzido
Enthusiast
I don't know why.
Thank you,
Uliwooly
You should be able to see a difference if you have a bright background (behind the object)
willsation
Hi.
Done that but not an option, it's not in the list.
However, I have just been told that these things are only available in Manual mode at  8mp !!
Got them now. Many thanks everyone.
willsation
Got it !!!
Thank you for your help.
Mr_Lu
1. If you want to maunully select HDR, use the Manual mode, HDR is listed in the options "3 dots is the option icon"
2. Why HDR cannot be used at 20MP? It is because of HDR's working way, HDR capture more pictures at same time, so that it needs to leave some "extra room/pixel" for processing. It's normal for HDR function supported devices.
MUSHARAB
Contributor
Why HDR is only available in 8MP . .  . .??
