sound enhancement crashing
DheerajSRao
Hey All,
Sound Enhancement is crashing on my Z1.
Not sure whether it was because 4.3 upgrade or becasue of the new version of WALKMAN (version 8.0.A.0.4).
I dont want to revert it back to factory restored version as it would be waste of time for me.
Please let me know whether this BUG can be fixed during ANFROID 4.4 upgradation. If yes i dont want to revert it back to Factory restore and if no I dont have any other option.
Thank you
profile.country.RO.title
_alexdon_
Sound enhancement crashing after 4.3 has been encountered before,it seems a software repair via sony update service fixes it:
http://www.sonymobile.com/gb/tools/update-service/
But before that,try to remove the updates for walkman app in settings-apps-all.
alexdon
5 REPLIES 5
_alexdon_
alexdon
DheerajSRao
Awesome Blossom...!!!
It Fixed.
_alexdon_
Great.
alexdon
Theresonly1cryo
Hi, I'm trying out this software cause I'm having the same issue, but it doesn't promote me to update anything and instead suggesting Factory reset
_alexdon_
You have to repair(not update).It will erase your memory.
alexdon
