Sony Xperia Z1 - not well heard of interlocutors
SMD
I am not well heard of interlocutors.
The same problem is present no matter how many speakers have spoken and their phone indifferent brand.
I am well heard when I use my headphones or use my phone on loudspeaker.
I hear well all of my interlocutors.
What should I do?
SMD
I did it, all clear now and checked, the problem was ``Microphone noise suppression``. Disable and now I am heard perfect.
9 REPLIES 9
profile.country.RO.title
_alexdon_
Try and disable slow talk(in call options it should be).
alexdon
SMD
It is disabled...
_alexdon_
Try and clear data for smart connect in settings-apps-all.
alexdon
SMD
Where to find that and how to do it?
SMD
_alexdon_
Settings-apps-all,look for smart connect.Tap on it,clear data and restart the phone.
alexdon
_alexdon_
Great,I am glad.
alexdon
SMD
Did that too now. Thank you very much!
_alexdon_
Anytime.
alexdon
