[Help] kitkat
bluemonkey
[Help] kitkat
Hey, got the z1. And my friend got the kitkat update but when i go inyo the "update thing" it says i dont have any updates. Why is this? And no. I dont have kitkat allredy. Thanks.
profile.country.RO.title
_alexdon_
It will reinstall 4.4.2,practically a fresh copy of 4.4.2.It helps a lot in some cases.
alexdon
13 REPLIES 13
_alexdon_
Check with PC companion and sony update service for the update:
http://www.sonymobile.com/gb/tools/pc-companion/
http://www.sonymobile.com/gb/tools/update-service/
alexdon
bluemonkey
I'll do that as soon as i get home from work, thanks for the fast reply!
_alexdon_
Keep us updated.
alexdon
bluemonkey
okay, it worked. Just that i got 4.4.2 and my friend got 4.4.3, im just conserned about other users got theire phone "Overheated" and when i tried to upgrade it "again" it says there is none. on both the phone and the PC.
_alexdon_
There is no more than 4.4.2 for now,you should try to reinstall using sony update service:
alexdon
bluemonkey
I downloaded that, and when it promted me to choose what model I got, there werent any z1 (C6903).
I'm really confused right now.
_alexdon_
You should choose SOL23.
alexdon
bluemonkey
uhh, okay, going to try this now! Thanks!
_alexdon_
Keep us updated.
alexdon
