Problem may perhaps be that the phone needs to switch between different networks at your location. Try using the phone in GSM only, WCDMA only and WCDMA/GSM for a while and see if that makes a difference. You can select network mode under Settings -> More -> Mobile networks -> Network mode.
If that doesn't help, could you try your phone with another SIM?
Clearly there's an app or apps acting up, that keep your phone awake, repair your phone with SUS or PCC
also stay away from taskillers, task managers, antivirus, battery apps, ram apps booster apps
Bridge (for Mac)
airplane mode will turn off all radios, could you post screenshots of the graph and the battery list, also tap on the top 3 items on the list and post them here
upload the screenshots to box.com and post the links here
screenshot = press and hold power & volume down at the same time
Your phone surely has a higher battery usage than normal. Sometimes this happens to mine as well, when some process in the phone just keeps it busy. I can detect when it has gone wild, as scrolling in the (Chrome) browser has lost the floating feeling when scrolling up or down a page.
Simple solution has been to restart the phone.
But it might be worth a little more analysis to track down the cause, as uliwooly guided you to.
you can upload it anywhere as long as you make the link public, if you turn off airplane mode, that tells you that either an app or apps are using your data plan quite a bit and/or you have really poor network coverage or both
take the screenshot (of the graph)
