and are you certain that you have the correct APN settings?
re-install the latest update with SUS or PCC and check again
Bridge (for Mac)
Do you have a data plan?
Is your data on?
Do you have any taskiller? antivirus? battery app? ram app?
which APN settings do you currently have?
MMS won't go through WiFi, Get a brand new micro SIM card
keep us updated
Bridge (for Mac)
