Hi. Please help.
I got my z1 compact 2 days ago having upgraded from a samsung s3.
The problem is that intermittently my z1 will answer the phone in loud speaker, I am running everything in stock with no launchers or 3rd party phone apps.
Please help, this is really annoying
Phil
Could be,Tomke.But it is known that Chrome has some issues.
Chrome has the ability to take over microphone and camera,so it is related to that.
Google released an update to Chrome yesterday via Play Store, mine is now at 33.0.1750.166
Let's see if that improves anything...
I don't think, that there is a bugfix for our problem in this update... this is the changelog:
http://googlechromereleases.blogspot.de/2014/03/chrome-for-android-update.html
Fixes issue where speaker mode is enabled if you pick up a call while browsing on Chrome. Fix has been verified on 1750_93. TBR=bulach BUG=348538 Review URL: https://codereview.chromium.org/198953002
M - /branches/1750/src/media/base/android/java/src/org/chromium/media/AudioManagerAndroid.java
--> If I click on SVN Revision log of the last update (http://build.chromium.org/f/chromium/perf/dashboard/ui/changelog.html?url=/branches/1750/src&range=2... I read this bug should be fixed. But I'm not familiar with all this developer-code language Anyone can confirm?
I just now recived a call after chrome updated to 33.0.1750.166
call went to speaker as before.
This seems just bad.Uninstall updates and try again.
Removed all updates going back to version 28.0.1500.94
Calls are not answered by speaker.
Now my browser is open to security risks.
I also noticed that if the magnetic charger input is connected (did not test it with USB yet), all calls go to speaker.
Updated back up to the latest Chrome app and now a surprise, calls do not go to speaker.
I will follow up if I see the bug returns.
Keep us updated.
