hi,
My vaio fz21m, doesnt recharged the battery.. it shows that the battery light is blinking, but if I try to remove the battery and just connect the ac adapter, then vaio doesnt turn on. but when the battery is plugged, it recharges and after sometime, the battery drains the power and the vaio shuts down. this is happening only since yesterday. currently i have only 1% battery life left. from 40% it drained within 10 mins. this is unbelievable please suggest a resolution.
If it will not run on the AC Adapter alone, this points to either a faulty AC Adapter or a powerboard failure inside the Vaio.
You are using a 19.5V 4.7A adapter?
Are you using the the original Sony Operating System and Driver Pack?
Can you try someone else's AC Adapter to see if yours is faulty.
!!!Sounds like you need to contact Sony Support on Monday here: -
http://support.vaio.sony.co.uk/contacts/contacts.asp?site=voe_en_GB_cons&cc=fr_CH
They will advise you on turnaround times and other details.
Sony will not guarantee your data will be retained. If you have important data on the hard disc, I suggest you buy an inexpensive caddy and remove your hard disc. You can then connect the caddy to another PC and copy from the hard disc.
Just make sure you buy a SATA caddy like this one: -
2.5 inch SATA USB Caddy
