I am having issues with I tunes and the fact the library keeps deleting itself. I have checked the apple forum and people are suggesting this is due to a conflict with vaio software....anyone else had this problem?
Hi pgtips78,
I'm having the very same problem, the songs may last on itunes for a week or so, then i'd open it up again and they'd all be gone! It's so annoying!! I don't have a clue as to why this is happening so i cant help you on that front! But your not alone on the library deleting itself the whole time!
I kept having this problem also, and Apple adviced me to uninstall Itunes, and reload the software, this didn't work for me. I did find that if you move your Itunes folder to a differnt file and use the new file as the location it worked for me. Hope it does for you, I had over 25000 songs and everytime it wanted to reload them, I got really fed up with it
