Alternative Monitor Display
GrahamM
Hi All,
I have a Vaio Notebook, VGN FJ3MW.
Sometimes I need to display on an alternative monitor or protable projector. This used to work ok, I could use the FnF7 button to choose between LCD / Monitor / Both. But now I only get the options LCD / SETUP. When I choose setup I can enable the second monitor, but only as an extention to the first monitor.
What I need is to have Both (LCD and Monitor) to display the same view at the same time.
Can anyone help please?
2 REPLIES 2
profile.country.en_IE.title
sonypass33
You should be able to do this in the display settings where you mirror what's on the screen. In some cases this needs to be changed in the graphic card settings.
GrahamM
Hi p2p2p,
I tried the display settings as you suggested and it worked.
Thanks for that.
Graham
