problem with xperia m2 dual
alvice2004
after a call of duty heroes installation from google play the phone shut down and it doesn'twork at all. can anybody help me?
Uliwooly
Connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2 to 3 hours
4 REPLIES 4
Uliwooly
Thommo
If that doesn't work then consider performing a system repair - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
alvice2004
thanks my friend. you were very helpfull
Uliwooly
Anytime, but it will be wise to backup and repair your phone
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
