2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
dspencer999
Really hoping this is a stupid question.
I have the KD55X8509C, and am looking forward to the YouView update hopefully coming during the next week, if you believe the Sony timetable.
However, following a quick google, I found this link, and my TV is not specifically listed; just the 8505C.
http://www.youview.com/news/2015/02/03/demand-more-from-your-tv-with-sony-and-youview/
I assume (hope!) this list is out of date?!
cozzykim
I don't think that it's out of date per se, it's probably just generic.
The last digit in the 850x number is just related to the 'Motionflow' spec, with (AFAIK) the '5' being the lowest spec and the '9' being the highest, as in 8505-8507-8509 I think that they're '800Hz', '900Hz', 1000Hz respectively.
A bit meaningless in the real world, as it doesn't signify actual refresh rates, just interpolated.
Happy to be corrected if this is wrong, as it's just from memory. :wink:
dspencer999
Phew! (replacement TV arriving tomorrow, so fingers crossed my other problems go away)
cozzykim
Kewl :wink:
Hope all goes well and you get to see the terrific picture quality at last. (Y)
Fingers crossed that the latest firmware starts to patch things up a bit too.
Tarpii
I've been without the featured apps section for some time, which meant no access to iPlayer. Thanks to this thread, I learned that the system app 'Sony Shelf' needed to be restarted, thanks guys!
My only remaining iaaue is that sometimes the sound on the homescreen, goes really tinny, i this a known issue?
Bring on the firmware updates Sony!
psp888
got a message from Sony when asking about Youview on their Android TVs, they said it will be available this Summer....  Why didn't they say this month? Delayed?
cozzykim
This summer :anguished: that means never then, because there isn't going to be a summer, sneaky huh?
Seriously, September is the start of autumn in the UK, everybody knows that, so it must be within the next week. :wink:
miroslavm
They have changed the update availability table: http://www.sony.co.uk/support/en/content/cnt-hn/prd-tvhc/more-features-coming-to-your-android-tv-soo...
Now most of the features are "Within this year" :slight_smile:
sassbs
they better not be leaving it until September to fix the 5.1 issues when the US has the fix already.
psp888
WHAT A SUPRISE!
Just as I predicted, end of the year, new TV's will be announced and they will just give up support on ours, leaving us with half sold functioning TV's/
WE HATE YOU SONY
