2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
profile.country.en_GB.title
gamorga69
Just be aware that the next update if the same as thre U.S will bring HDR to the x93c and x94c as well as 4k 60p 4:4:4. Awesome news for my x94c.
dspencer999
cozzykim - No. Still got the PQ problems, and will look to get a replacement tomorrow, but it's brilliant news that Plex is potentially fixed for everyone. Just watching Avatar in HD, which was stuttering and pausing previously, and kept coming up with an error message that the server was too slow.
Has anyone else tried Plex since the latest server update? Make sure Direct Streaming and Direct Play are set to YES now.
Tigermad71
Can I watch all my media on plex that is in mkv format through an 850c TV?
Abercrombie
Tigermad71 - in short, yes, Plex does play mkv files. At the moment I find Kodi tends to play the files a bit smoother (and with 5.1 sound), without the occasional stuttering that Plex seems to have now and again.
Sent from my iPhone
Shalendran
I too have the same problem with my W85C, with sound coming from two sources simultaneously. The problem has reappeared after the latest update. I think it is something to do with HDMI with ARC. I just select the correct HDMI source and switch off the other equipment!
regards
mk1.golf.1983
I just came up with issue on my W75C. Turned on the Playstation 4 and changed channel to HDMI1 and no picture, baffled I turned off the ps4 and tried again still nothing. Change to HDMI2 still nothing. Hard reset of tv (unplugging power lead) and now it's working. Today I installed kodi but not used it and also today I have been streaming soundcloud from my phone to the tv, that is the only thing that I have done different today. Glitch in the matrix?
cozzykim
Yep, mine does this too, a minor annoyance but...
I usually manage to regain a picture by switching to TV (Digital) input and then back again.
cozzykim
@BHolla47
Did you fix the wobbly stand?
psp888
still no update today, so disappointing
mk1.golf.1983
 But it's not the End of August.
