We're always a week or two behind. Possibly because itll be the same QA team. Europe has different tuners from the US so they're slightly different models
Do they have YouView style rollback in the States? Maybe that's why the new firmware can be rolled out earlier there if not, if indeed it has.
Interesting, let's hope there's some truth in that
Potentially good news!
I have just installed the latest Plex Server update, set my Direct Play and Direct Streaming to ON.
Both Local and Remote are set to Original.
Suddenly, all of my problems have gone away generally.
Got the message about server being slow just the once, but the video continued to play with no problem. Give it a go!!!
That still doesn't solve your PQ problems though, does it?
yesterday I turned my automatic update to off as my TV has no problems at the moment and if I update it will no doubt go wrong. I'm not bothered about you view I use sky for TV I've not watched one show yet on the built in freeview. As long as my PlayStations work and sky I'm good with that. I'll wait and see if the next update bricks the TV's before I install it.
