Anyway, you are no longer on safe mode, so your problem its solved, as for the icons on your homescreen perhaps you have reset the phone
Don't forget to give Kudos
did u fix this problem?
Yes this was the closest thing to a resolution . My phone was out of Safe Mode,however no longer had most of the configuration I had already done such as , apps in folders on the home screen. So i had to configure it from scratch
Hi, I've got the same problem. Already did the power and volume up, did an complete reset of the phone, even used the red button next to the simcard. Nothing is working, I work in a phone store and non of my colleges had success either
Repair phone software with sony update service.
i got the same problem with a safe mode, but can i fix it by my self if bottom (volume down ) doesnt work ?pleas help.
No,you should visit a sony service.
jup but they want me to pay 300£. i think thats to expensive
For volume down so much?Or is it a problem with the motherboard?
