My z5 dual wifi works fine with router but when I connects it to my other mobile lyf flame 5 it drops wifi on hotspot
I tried ota update factor reset and hardware check by workshop but problem is still there
I'm a bit confused, are you saying that WiFi stops working when you enable Hotspot? if so, that's how it's supposed to work
Hot spot enabled on my lyf flame 5 the other mobile and z5 connected via wifi but wifi keeps stopping
Wifi notification goes and than reappear and than goes
Ok, could you test the hotspot with a different device, also, forget and add the hotspot again.
Hi Sam38,
Welcome to the community,
It may also be a good idea to contact the manufacturer of the device that is providing the Hotspot, as this seems more Hotspot device orientated.
No worries glad we could help
I have a Z5 compact and my friend an Z3+ only on android 6 the signal is broken even often 4g (LTE) mostly and wi-fi. On android 5.1.1 and 5.0.1 there are no problems at all! We did a downgrade after the automatic system upgrade to 6. Bad upgrades regarding also the sound quality and camera's (the quality is better on factory generic firmwares)!
I hope this helps!
I have messed around with this for months. I have been through two sets of Xperia Z5Dual and it is the same. From what I have read it is a problem in Android 6.0. Google might have fixed the problem in stock android but Sony haven't got around to pushing out a fix...
Anyway I have found that the phone's connection is much more stable on previous iterations of the WIFI standard. The modem/router provided by my ISP will only operatin in 802.11AC, so I went out and bought a second hand 802.11N AP just to user for my phone (http://www.netgear.com/home/products/networking/wifi-routers/WNR1000.aspx?cid=wmt_netgear_organic).
It is kind of stupid hack to have to set-up a WIFI network just for my phone but a US$15 router beats replacing a US$600 phone...
