I've got 5.1.1 and my phone loses connection to everything periodically. I then have to re-download sms and Internet settings, in order to use the phone. I've already did a reset factory reset but it still has 5.1.1...
even manual... I have no acoustic feedback for any kind of notification. Hopefully somebody has a solution for this. And yes, the loudspeakers are working, I am able to watch YouTube videos
Hi petercs,
You can turn off vibration for calls under Settings > Sound & notification. If you want to turn vibration off for certain apps then you need to go to each app's settings individually & change this.
For example: If you want to turn vibration off when you are receiving SMS notifications, just go into the Messaging application > tap the three dots in the top right hand corner & tap Settings > Untick Notification vibration.
