The problem is that the phone stopped detecting the sim suddenly Vovi her out and replaced and it worked but it has happened again and no longer detected at all ... the card was cut at the store because it was not microsim format could be this the cause? can serve the red button next to the place where you put the sim?. Thank you.
Thanks for the reply, I suspect something ..... I would like to know something about the use of the red button if anyone knows how and when to use
If you want to reset your phone you will press and hold that button
http://www.xperiaguide.com/2013/09/12/xperia-z1-comes-with-a-physical-hard-reset-button/
Anytime
