- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2014
January 2014
My phone went to sleep then i tried to press the power button it doesn't light up. Notification lights up, i can do reset(power+volume up). After i reset it, holding power button show turn off option. I've tried to remove my sim and sd card but nothing happens.
What to do? THANKS!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Connect to wall charger,charge for 1-2 hours,force restart the phone(power button+vol up until the phone vibrates).
alexdon
11 REPLIES 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
@alexdon thanks!! It worked. May i ask what cause the problem?
Thank you so much! More power to you and sony team support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Did you let the phone discharge almost completely?
alexdon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Nope. It happend at around 50%-30%.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Were you using task killers or battery savers?
alexdon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Im using advance task killer. I've read other posts so i've un-installed earlier.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Yes,remove any task killers,battery savers,even antivirus.Stamina mode is more than enough.You can force close apps you do not use.
alexdon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Ok. Thanks again. More power!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
You are welcome.
alexdon
