Hi ! My Sony Xperia Z5 is making a noise from the bottom speaker i would ask if there is an officiel Sony Center in Algeria so that i can repair my smartphone .Thank you
Thank You for your efforts but i didn't find my country in that list if i try to reset it, the problem can be solved ?
From a Guy Who buys and sells phones … but it Was working perfectly until today when i put my headphones it began
If he bought it in a different country the warranty will only be available in that country, it doesn't hurt to do a software repair
http://talk.sonymobile.com/thread/36355
I tried the XC same issue but the sound is a little bit better after a week i will see if it'll je solved
