Has anyone enabled Talkback feature? It freezes the phone and slows down like anything that I couldn't even scroll down.. What the heck is this???
one advice, as soon as you get your phone, repair it with SUS or PCC
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
it works on my Xperia Z, uninstall any taskiller, antivirus, battery app > restart your phone and try again
I checked it on a brand new phone without any apps installed on it.. Anyway, I have sent my phone for replacement (due to no vibrations) and hopefully will get a new one in next 4 days.. So i'll check it after that.. I hope I dont come across any more problems...
Okk bro.. is it the 10.1.A.1.434 update? I'll do it as soon as I get my handset and after that install the apps..
BTW, any way to increase the speaker volumes? I have come from my lovely Arc to XZ and find it very low..
something odd my build number is 10.1.A.1.350, its not on the list.
http://www.ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=22706
| Manufacturer: | Sony Mobile | ||||||||||||||||||||
| Model #: | C6603 (PM-0270-BV) | ||||||||||||||||||||
| Supported Technologies and Frequency Bands: | E-UTRA FDD: Band 1/Band 3/Band 5/Band 7/Band 20, GSM: 850/900/1800/1900, UMTS FDD: Band I/Band V/Band VIII | ||||||||||||||||||||
The Xperia Arc's loud speaker its amazing, from all my Xperias its the loudest, the Xperia T/TL its the closest followed by the Xperia S then X10 the Xperia Z it's somewhere between the T and S, then again the Xperia Z its waterproof
Hmmm.. So it means I'll hv to live with it now..
Yup.. Follow XDA regularly..
Thanks for your help bro.. Cheers!
