I just bought an Xperia Z1 C6903, and there was a charging dock in the box, but it doesn't seem to work?
I can charge the phone using a USB cable, but if I connect the charging dock to the same USB port and put the phone properly in the charging dock, the phone is NOT charged....?
Are you connecting the charging dock to a USB-port on your PC? If yes, this will not work. You need to connect the charging dock to a wall socket to be able to charge your unit.
