CHARGER HEATING HEATING
MUSHARAB
Contributor
Does your Z1 Charger (EP880) heats up while charging, My charger is getting too much heated while charging my Z1. What could be the possible reasons  . . .??
Archanos
Contributor
It's absolutely normal, especially if you charge the phone from low battery level.
Start worrying once the charger stop getting hot at all Winking_Face
No, really - it's completely natural. It is hi-efficiency one, 1500mA current supply at 5 Volts, it has to get hot. Until it is not getting very untouchable-hot and smelling/melting, there is nothing to worry about, it can get hot up to 70 C temperature and it is normal.
1 REPLY 1
Archanos
Contributor
