I wonder if I could use the charger from my old HTC Desire Z phone to charge the Z1 Compact? They both use identical USB cables attached to a wall socket-usb adapter. I guess the only danger is that if the old charger provides significantly more power, perhaps it could damage the Z1. I can't find any documentation that says what the actual power requirement is for charging. I'm hoping that all the power-usb adaptors provide the same voltage?
Thanks
damaru-inc
Canada
You have to look for the voltage,it must not exceed 5V.The amperage does not damage your phone.But it is recommended to use sony original chargers.
Thanks, it works.
yes i'm useing my samsung charger and all seem's ok also use comodo battery saver you'll see it take's same time to charge on samsung or sony charger
