Can I charge it using a non-sony charger?
damaru-inc
I wonder if I could use the charger from my old HTC Desire Z phone to charge the Z1 Compact? They both use identical USB cables attached to a wall socket-usb adapter. I guess the only danger is that if the old charger provides significantly more power, perhaps it could damage the Z1. I can't find any documentation that says what the actual power requirement is for charging. I'm hoping that all the power-usb adaptors provide the same voltage?
Thanks
damaru-inc
Canada
profile.country.RO.title
_alexdon_
You have to look for the voltage,it must not exceed 5V.The amperage does not damage your phone.But it is recommended to use sony original chargers.
alexdon
4 REPLIES 4
SirRobin
Contributor
It should be now problem to charge with a non-sony charger - i´m using a nexus 7 charger with 2,0 A since the Xperia Z Grinning_Face
Gruß Sir Robin
--> KD-55XE9305 --
_alexdon_
alexdon
damaru-inc
Thanks, it works.
Trev58
yes i'm useing my samsung charger and all seem's ok also use comodo battery saver Winking_Face  you'll see it take's same time to charge on samsung or sony charger
