Guys,
I have updated Xperia ZR to 10.4.1.B.0.101 and found that now Battery Draining Fast After updating as compare to 4.3
Have any solution???
@NAYAN_GOKULL wrote:the PHONE is getting adapted to the new firmware ... the stamina mode and some more processes drains battery..this may take a few days r a week for your phone to get cool with the situation.Be patience and ENJOY THE EXPERIENCE
PMFJI. This response plus the one above makes no sense. There is no "getting used" to firmware or "getting cool" with firmware. Stamina mode should not be any drain on battery -- it is designed to save power!
Aside from a system bug, what I have found is that new OS upgrades often contain new settings. Sometimes, a careful review of the settings may expose something. In addition, looking at the Settings/Battery will show you which applications are draining the most power (normally the screen) but may lend a clue.
I have found across all OS versions from 4.2.2 to 4.4.2 (yes, I am running kitkat), lowering sleep time to 30 seconds or 1 min and not using wifi and KEEPING your screen off will save battery.
But please, no more "getting used to" misinformation.
