Battery Draining Fast After updating 10.4.1.B.0.101
immifraax
Guys,
I have updated Xperia ZR to 10.4.1.B.0.101 and found that now Battery Draining Fast After updating as compare to 4.3
Have any solution???
LukaLuxXD
Until your battery returns to normal, I suggest you do this:
1. Reduce your screen brightness
2. Turn auto-sync off
3. Remove any live wallpapers
4. Remove widgets
5. Turn Stamina mode on
And if that doesn't help, go to PC Companion and repair your phone
10 REPLIES 10
Danial-mach1
Leader
Just wait..after some days it will fixed....its take time to update settle down and things back to normal
NAYAN_GOKULL
the PHONE is getting adapted to the new firmware ... the stamina mode and some more processes drains battery..this may take a few days r a week for your phone to get cool with the situation.Be patience and ENJOY THE EXPERIENCE
immifraax
thanks guys,
lets see for few days and will update u
immifraax
Now it is almost a week but i observed battery draining fast as said before
Any thing to do to resolve???
Danial-mach1
Leader
try to boot in safe mode and see if battery still drain fast(how to boot in safe mode)
maybe 3rd party app is acting up...do you have any task killer battery saver or this kind of apps?
keep in mind that may take more time than week to new sw settle down
LukaLuxXD
4. Remove widgets
immifraax
Thanks baddies
I hope above given steps will work
JimmyJazz
Turn off Nfc, Bluetooth and Gps If you dont use them, made wonders for my battery life.
immifraax
i have done steps, and also repair phone via SUS, it looks that problem has been resolved
