Hi all, just received my first ever vaio (fw21m) through the post, laptop is ace but just got one little niggle, would be great if anyone could help me out!
When I want to change volume using the hotkeys or press the S1 button to get to the Dolby control centre, I get a bleep from the computer to show me how loud the volume is! This is getting really annoying, especially when I'm in the middle of watching a film. Anybody got any ideas how to turn it off?????
Cheers, billo1187
Hi billo1187,
welcome to Club VAIO..
The bleep sound you are referring to is called pi.wav, this can usually be found in C > Program Files > Sony > VAIO Event Service.
Instead of simply deleting the pi.wav file I would suggest renaming the .wav file extension to something else . Then if ever you want to restore the bleep sound you can just change the name back.
If you can not find the file in Vaio event service try doing a system search for pi.wav.
Hi billo1187,
welcome to Club VAIO..![]()
Instead of simply deleting the pi.wav file I would suggest renaming the .wav file extension to something else . Then if ever you want to restore the bleep sound you can just change the name back.![]()
