Hello,
Anyone got a service manual for this laptop, or step-by-step instructions for gaining access so I can swap my hard drive?
I've got a faster RPM drive with larger cache that I would like to do a clean install on.... Eventually I will fit an SSD drive when they are more affordable.
I'm technically very good, but the lack of a drive "panel" or "caddy" as you normally fine on most laptops kind of threw me
Cheers,
Jamie
Hello
I believe upgrading the hard drive is very difficult on this series,
I am still in search of instruction on how to upgrade to a Blu-Ray drive
Regards
Gokhan
Hi Guys.
I undertand it is a difficult process and is almost certain to void the warranty.
http://forum.notebookreview.com/showthread.php?t=272690&page=90
