Problem with the optical out
dom99
I have a Sony Vaio VGX-TP2B entertainment center. For some reason if I plug a cable from the optical out into my amplifier the amp receives no signal. Its not a problem with the amp as ive tested it with other digital gear which works ok. Is there some sort of software adjustment I have to make to get the optical out to work on this model?
1 REPLY 1
Blencogo
Hi dom99 and welcome.
Have you tried everything in the manual?
