Need network drivers for XP for VGN-C2S/L
Smiley_ie
Hi all.
I installed XP on this Vista laptop and managed to get video and audio drivers working, and cant get any for onboard lan and wireless anyone no what drivers i need.
Intel chipset detect software says 945g ive tried lots of different ones with no luck.
2 REPLIES 2
Thalamus.
Champion
Hi Smiley_ie,
You should find the XP drivers you require by using the C1 series Original Drivers & utilities Packages from Vaio support, use the following link to download: the C1S Original Drivers & Utilities Packages
Once you have downloaded the packages you will need to extract the files..
Smiley_ie
Thanks Thalamus worked like a charm.
Cheers m8.
