hi i have N38E/W. laptop i am very happy with that but i dont know whats wrong with the strat up.its bit slow is any one out there to help me out.thanks
Hi there
Do you have alot of applications that run on startup?
Also have you cleared your temp files / browsing cache etc recently?
Sometimes too many programs loading on startup slows the system down as can having alot of
temp / junk files.
There are apps like ccleaner which are very useful for clearing these files but be very careful with the settings.
Have you scanned the system for spyware / viruses too?
