help anyone..i want to change the operatng system from spanish to english..
adan0983
you see, i bought this laptop VGN-fw11l in spain but i cant understand the languange..i dunno if there´s a software available in the internet that will be able to make my OP english.. help anyone.i tried installing windows vista home premium english version but the probem is the battery checker ¨battery is not compatible to my computer it says.. wah!!! HELP!!!!! i appreciate any help or tips you cn give.. thanks>>>>
2 REPLIES 2
profile.country.en_GB.title
micdonal
If you go into Control Panel and click on Clock,Language and region settings then try "install/uninstal display languages it will take you Windows Update where there will be options of Language packs to instal.
Blencogo
I think these language pack options may only be available with Vista Ultimate installed - not available with Vista Home Premium.
adan0983, have you reinstalled ALL the drivers and ALL the Utilities?
:thinking:
