Fn key(Blue Color) is not working PCG-k115B
majidnt
Can any one help me out to slove the problem. My Sony note book model PCG-k115B, The Fn key (blue color) is not working after my new installation. If anyone can help..
Thanks.
2 REPLIES 2
Blencogo
Hi majidnt and welcome to Club Vaio.
Is your 'new installation' from a Sony Recovery Disc or have you installed a retail Windows operating system?
The Sony Utilities control the use of the special keys and you will need to install these if you are using your own version of XP. You can download the Utilities package from here: -
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&c=0&s=PCG...
Right-click on the downloaded K1_Utilities.ZIP and choose "Extract All". Extract to C:\. Run C:\Utils\Utils.exe
:wink:
majidnt
Thanks buddy.. it works..
Thank you again.
