The DVD drive in my desktop has stopped working.
The model of the drive is the Sony DVD18A. I do not use it for much - mainly for watching DVDs (the desktop is used instead of a DVD player).
The DVD18A model no longer appears to exist. What DVD Drive can I buy to replace it with - preferably something for sale on Amazon.co.uk or similar.
Thanks for your help!
What model Vaio do you have - some are a bit difficult to replace the drives.
If you have a conventional desktop tower any 5.25 inch internal IDE drive should fit. If you have an 'All In One' then it will probably have a notebook drive.
Go to Amazon and search for DVD IDE internal drive and you should get a very good choice from £15.
Thank you for your help. The model is VGC RA104.
I think it is quite tricky to get the drive out. Hopefully someone here will be able to help.
I think Kee-Lo has replaced his?
