Downgrade to XP on AR71S HELP PLEASE
KasimVaio
Hey, I want to downgrade to XP from vista on my AR71S. Where Can i download the drivers to XP? Help PLease
1 REPLY 1
Blencogo
Hi KasimVaio and welcome
There is no XP Drivers or Utilities Package as Sony do not support XP on your model. Newer models are designed to run on Vista so some of the machine's functions will not work with XP.
Installing XP is no easy task but if you must, have a look at this thread by costasp -
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=41647
:slight_frown:
