hello peeps
would appreciate advice re defraging the hard drive. Is it safe to do so even though the recovery files are also on this drive, I have been told that you can potentially harm the files. I have a Sony Vaio noteboook VGN-11e
any help appreciated.
Bob W
It’s perfectly safe, not only that, it’s recommended. Widows just slings things over its shoulder when you hit save and a defrag picks up the mess windows has made and puts it into some sort of order. This means files that should be together are now together and the hard drive isn’t zipping all over the place to find fragments of the hand grenade windows has made of your hard drive. Afterwards the computer should be faster than before as it doesn’t need a roadmap to find stuff.
Warning: Depending on how big your drive is it can take a long time, several hours so plan ahead before you do it so you don’t need your computer in the meantime.
Hi Bob W,
just to say thanks for the advice.
Bob W
