battery not charging
mrvaion20
i purchaced a sony vaio ns10j/s 3 days ago and suddeyly the battery stopped charging vista says its charging and the battery charging light is on but nothing can any 1 help plz
3 REPLIES 3
Thalamus.
Champion
Hi mr vaio n20,
some Vaio models have a Battery Care Function this usually stops charging at approximately 80%, is that what you are experiencing.?
mrvaion20
thanks 4 help no thats no wats happening it wont chare any more than 1%
Thalamus.
Champion
Hi mr vaio n20,
try removing and replacing your battery again, ensure it's securely locked..
Did you buy your Vaio locally if so a simple way to check if this is a battery or possible hardware problem is to take your Vaio to a local stockist and ask if you can try another NS's battery in your Vaio..
If this is not possible then I suggest you contact Sony Vaio support, you can do this either by phone (0800-1800 Mon - Fri) or via e-Support, use the following link to find the contact details: Sony Vaio Support
