A typical answer from sony
stavrosserres
I had posted an other thread about a problem that I had with the AW11 M/H. After sending my laptop to them, after long hours trying to explain the problem (a sound that was coming out of the HD) after recording the sound my self the only thing that I managed was to make them admit that yes there is a sound (I thought great at least they can hear it too) BUT it is normal and within specifications.
Please find the time to hear the noise and tell me if you thing that this is normal.
Thank you
Sorry for not attaching the file a small problem occured.
0 REPLIES 0
