Hello,
I am wondering if Sony M2 Aqua has option to vibrate on answer and hang up call like other Android phones. I'm using Android 4.4.4.
Explanation: http://teckfront.com/set-vibrate-android-kitkat-4-4-2-phone-hang/
Thanks
By default I am not aware of how you can do that. You could check XDA forum.
As you were told on XDA you need to root and either Deodex or Odex your Rom and install an Xposed module
I have managed to get vibration on answer and hang up working...
Search on google play for: Vibrate Call
And NO ROOT REQUIRED
and on here by Uli you were advised to just that
