in settings->system->accessibility-> magnification features , make it disable and see, for me it worked after disabling it . hope it will work for you also.
Double tap zoom cannot be disabled,normally it should not be active while you are in a game.
What games do you play?Double tap zoom should not be active in games installed on your device.
Well,it should not...I do not know why could the phone do that.Try a force restart(power button+vol up until the phone vibrates).
Repair phone software with sony update service.
Retry with pc companion.
