just download apps from the playstore and check the app permissions before installing them.
Where in the world are you and where in your phone did you see this?
Follow @Phy suggestion, if you don't get that option while on safe mode then its a third party app, btw is your phone from China?
Do you get both options while on safemode?
Then that show its an app that you installed either through the play store or if you sideloaded an app, you can uninstall apps or just repair your phone with PCC, I would do do that (repair my phone with PCC)
