Can I stream Blu-Ray to PC(Vaio) from Blu-Ray Player?
RÉSOLU
profile.country.en_GB.title
iagibso49
Membre
Can I stream a Blu-ray via WiFi from my player to my PC? I have everything on my Wireless N network.
Message was edited by: iagibso49
1 SOLUTION APPROUVÉE
Solutions approuvées
Catmambo
Contributeur
No, even if the DRM permitted it, the data throughput would likely cripple your network.
Thanks
6 RÉPONSES 6
Catmambo
Contributeur
Thanks
iagibso49
Membre
Why would it cripple my data? I can stream other HD stuff over WiFi, such as that held on my computer. The whole point of Wireless-n is to stream HD.
What's the point of having a DNLA enabled Blu-Ray then?
Catmambo
Contributeur
Blu-ray doesn't have as much compression so you are looking at much higher bitrates of up to 40mb/s rather that 3.5mb/s used by services like BBC iplayer or higher for HD video files. Its a moot point in any case as like I mentioned the DRM doesn't allow it anyway.
The idea of DLNA on Blu-ray is to allow you to stream content the other way from your PC to your TV/Blu-ray player as most people prefer to watch content whilst relaxing onthe sofa rather than leant forward on a desk on a laptop or desktop.
iagibso49
Membre
Yes but the principle is no different to a slingbox so I don't see why DRM should be an issue.
Catmambo
Contributeur
Whilist the theory is similar, the reality of Hollywood's approach to content protection and DRM is fundamentally different.
iagibso49
Membre
So how is recording a Hollywood film and streaming it with Slingbox any different to streaming to my PC in my bedroom from my blu-ray player?
