When I connect reader to computer (Mac) the Reader Library fails to recognise Reader and displays "Error", is there a fix?
Hi all
If you have the new Lion or Snow Leopard and run 64-bit OS, you will need to use the new Reader software, it has been stickied on the forum https://www.sony.co.uk/discussions/message/690244#690244
I have the same problem. Did you install Lion?
Hi all
