Sony Nex 5k - 18-55mm kit lens - infinity focus
I have a Sony Nex-5k and am having problems putting the lens into infinity focus - the lens is the std 18-55mm kit lens and does not have the infinity symbol on it. It is too dark to focus on a distant object and the focus ring just turns I definately so no way to set infinity by turning it a certain number of times. Any help with this would be much appreciated.
4 REPLIES 4
profile.country.NL.title
albertdros
Contributor
unfortunately this is a known issue with the kit lens. You probably don't want to hear this answer but I haven't seen a workaround on this. You just have to focus on lights in the distance I'm afraid 😞
profile.country.BE.title
Portmixus
Hero
If I'm not mistaken, you can use focus magnifier and then a distance bar is shown!
Sony Alpha Training
albertdros
Contributor
I'm not sure if that's the case with the NEX portmixus. I know my little brother has one (not the 5) and it doesn't.
Portmixus
Hero
I don't have NEX 5 anymore, so you're probably right.
But it's perhaps useful info for others with newer models.
BTW you can either turn towards the infinity direction as a loop then stop. (and if necessary turn it a hair back). Works in practice for me.
You can also "learn" the behaviour of your lens in broad daylight, and see whether your lens goes beyond infinity or not.
Sony Alpha Training
