Hi
How do I download Image Data Converter update?
my system tell me update is available but it does not connect me to the place on the site?
Hi ncollins
The latest updates for the a77 can be found here:
http://www.sony.co.uk/support/en/product/SLT-A77/updates
IDC is described as Software update procedure , 25/10/2011 and is currently at v4.0
Mick
Hi ncollins
Mick
Thanks Mick
I am as blind as a bat. I was on this page and did not see it....
Niall
I did the exact same thing at first – hence the rather elaborate post!
No need for an optician, just a crash course in Sonyese
Mick
