How does the battery grip fit the Alpha a77 and what happens to the existing battery cover
Hi ladyarch
It screws into the tripod mount on the bottom of the camera using an integrated knurled knob. Fits very solidly, feels very much part of the camera once in place.
There's a slot inside the battery grip body that the opened A77's battery cover sits in.
Mick
Thank you for your help
You're most welcome
