Xperia 1 III charging problem
danyelB35
So, have this Xperia 1 III since is been on the market (a few months) and been a Sony user for years.
It came with android 11 and updated to 12 when was automatically available.
Back in UK everything worked fine and never had a problem but now I decided to have a holiday and since I'm here (in Mauritius) doesn't matter the place, never charges properly.
I connect the genuine charger and the phone normally starts to charge but every 30-40 seconds this gets interrupted  and I get not charging notification. Next second is charging again and then not charging.... and on-off, on-off until eventually I get a usable battery percentage.
The charging port is clean, same genuine charger.... nothing in hardware changed.
Is it the heat (daily 30 degrees)?
Is it something related to local electricity?
IamNic
Hello @danyelB35,
have you tried another cable or another charging brick? Sounds like either one could be damaged.
- Nic
1 REPLY 1
IamNic
Hello @danyelB35,
- Nic
