Hx 99 metadata for HDR images
Tony_tea
Is there anyway of accessing the metadata showing whether an image was shot with HDR Auto. I see it when the SC Card is in the camera, but not when I transfer it to my Mac, using Lightroom. It must be recorded somewhere in the image, but is it accessible to Lightroom or similar?
Thanks for any advice that you can give me
Tony_tea
Hi - Thanks for your response - Imaging Edge more readily displays the HDR/DRO setting used to create the image so it is useful, although it would have been useful if this could also be done in Lightroom (where I have a library of 20 years of travel photography). However the data is much more accessible than using ExifTool and/or JFried's Lightroom plug in.
Does Imaging Edge also provide a tool to process Bracketed images to HDR?
Thanks for your help
2 REPLIES 2
SatoruGojo
Hey @Tony_tea, you can try with Imaging Edge.
Tony_tea
